K6.iteration_duration metric value
Hello! total time shown in test summary is 18m33.2s
But iteration_duration metric shows different.
Please explain how to relate these 2 values. Also, how do I get total test run time (18m33.2s) as a metric. Thanks
Hi there :wave:
I’m confused by your first screenshot. It shows you’re running with 1 max VUs, but the summary shows 10 VUs were running. Can you share your script and the command you used to run it?
k6 doesn’t expose a metric of the total duration of the test run, but you could create a custom metric to track it. Something like this:
import { Trend } from 'k6/metrics';
const total = new Trend('total_runtime');
export function setup() {
  return Date.now();
export function teardown(startTime) {
  total.add(Date.now() - startTime);
This is not ideal, as teardown() would fail to run if there was an unhandled exception, but hope it helps.
