K6 Failed to push trace samples to the cloud
I am attempting to enable traces in our k6 cloud run tests following the documentation here: Correlate results with Grafana Cloud Traces | Grafana Cloud documentation
The service endpoint I am calling in the K6 test has otel traces enabled (confirmed this as I can see the test traffic in Grafana Cloud Traces when running the script locally).
My k6 script includes the following:
import tempo from ‘https://jslib.k6.io/http-instrumentation-tempo/1.0.0/index.js’;
tempo.instrumentHTTP({
// possible values: “w3c”, “jaeger”
propagator: ‘w3c’,
And I confirmed that the test request has the Traceparent request header.
However, when I attempt to run the k6 script with the following:
k6 cloud run --local-execution .\DocMgmt_svc.js -e scenario=smoke_test -e K6_CLOUD_TRACES_ENABLED=true
I see the following output in the terminal, and no trace data is available in the Grafana Cloud test run:
ERRO[0012] Failed to push trace samples to the cloud error=“failed to ingest request metadatas batch: code=Unavailable, msg=connection error: desc = "error reading server preface: http2: frame too large"” output=cloudv2 t=2.7082311s
Thanks for sharing the issue! For future reference and to help others who might run into the same problem: the error message was quite misleading. The root cause was that the URL https://grpc-k6-api-prod-prod-us-east-0.grafana.net:443, which is required for this feature, was blocked by a proxy. This URL is used to send metadata about HTTP requests and tracing, allowing k6 cloud backend to correlate them with the service under test tracing.
In addition to the note above, we were running into a second issue with the error:
ERRO[0111] Failed to push trace samples to the cloud error=“failed to ingest request metadatas batch: code=Unavailable, msg=connection error: desc = "transport: authentication handshake failed: credentials: cannot check peer: missing selected ALPN property"” output=cloudv2 t=2.8764ck peer: missing selected ALPN property"" output=cloudv2 t=2.8764534s
We ended up being able to resolve this by enabling SSL_Bypass on our web proxy. Apparently the decryption/inspection was causing issues, and disabling that for the traffic going to https://grpc-k6-api-prod-prod-us-east-0.grafana.net:443 resolved it.
