I’ve been trying to get our K6 browser tests running inside our CI pipeline using github actions.
I initially tried the documented way on the K6 site using: uses: grafana/k6-action@v0.2.0 .Obviously this did not work as that’s not installing the K6 browser so I have now got the following set-up:
jobs:
k6_transpile_bundle_test:
name: Transpile, bundle and run
runs-on: ubuntu-latest
steps:
- name: Checkout
uses: actions/checkout@v3
- name: Install dependencies
working-directory: ./qa/performance
run: |
npm ci
go install go.k6.io/xk6/cmd/xk6@latest
xk6 build --output xk6-browser --with github.com/grafana/xk6-browser
- name: Run load test
run: |
./xk6-browser run tests/performance-test.js
but this returns:
go: downloading go.k6.io/xk6 v0.8.1
go: downloading github.com/Masterminds/semver/v3 v3.1.1
/home/runner/work/_temp/8c43b3f6-25e4-464b-ba9f-a2c6341234fb.sh: line 3: xk6: command not found
Error: Process completed with exit code 127.
Can anybody advise the best way to work with github actions and K6 browser?
TIA
