I’m new here, and I’ve a k3s kubernetes cluster, i’ve enabled on grafana cloud the Observability→Kubernetes, I’ve installed successfully the chart with the values, but plenty of data is totally missing on grafana cloud if i enter to a workload, all cpu and ram metrics are not there, is supported k3s?
helm upgrade --install --timeout 300s grafana-k8s-monitoring grafana/k8s-monitoring --namespace “monitoring” --create-namespace --values values.yaml
cluster:
destinations:
- name: grafana-cloud-metrics
type: prometheus
url: https://prometheus-prod-58-prod-eu-central-0.grafana.net./api/prom/push
auth:
type: basic
username: “2808467”
password: … - name: grafana-cloud-logs
type: loki
url: https://logs-prod-039.grafana.net./loki/api/v1/push
auth:
type: basic
username: “1399911”
password: …
clusterMetrics:
enabled: true
annotationAutodiscovery:
enabled: true
clusterEvents:
enabled: true
nodeLogs:
enabled: true
podLogs:
enabled: true
kubelet:
enabled: true
cadvisor:
enabled: true
alloy-metrics:
enabled: true
alloy:
extraEnv:- name: GCLOUD_RW_API_KEY
valueFrom:
secretKeyRef:
key: password - name: CLUSTER_NAME
value: my-cluster - name: NAMESPACE
valueFrom:
fieldRef:
fieldPath: metadata.namespace - name: POD_NAME
valueFrom:
fieldRef:
fieldPath: metadata.name - name: GCLOUD_FM_COLLECTOR_ID
value: grafana-k8s-monitoring-$(CLUSTER_NAME)-$(NAMESPACE)-$(POD_NAME)
remoteConfig:
enabled: true
url:
auth:
type: basic
username: “1442117”
password: …
alloy-singleton:
enabled: true
alloy:
extraEnv: - name: GCLOUD_RW_API_KEY
valueFrom:
secretKeyRef:
valueFrom:
fieldRef:
valueFrom:
fieldRef:
remoteConfig:
enabled: true
url:
auth:
type: basic
username: “1442117”
password: …
alloy-logs:
enabled: true
alloy:
valueFrom:
secretKeyRef:
valueFrom:
fieldRef:
valueFrom:
fieldRef:
fieldPath: metadata.name - name: NODE_NAME
valueFrom:
fieldRef:
fieldPath: spec.nodeName - name: GCLOUD_FM_COLLECTOR_ID
value: grafana-k8s-monitoring-$(CLUSTER_NAME)-$(NAMESPACE)-alloy-logs-$(NODE_NAME)
remoteConfig:
enabled: true
url:
auth:
type: basic
username: “1442117”
password: …
