Joining two API queries with key:value pair and join on "key" field
We have two queries using JSON API datasource and both returns data in JSON format as below;
Query-1
{“1”:100,“2”:27.7717391305,“3”:214,“4”:28,“5”:0,“6”:25.104,“7”:28807.407,“8”:-348201.3876}
Query-2
{“id”:1,“n”:“Device Battery”,“t”:“custom”,“d”:“”,“m”:“%”,“p”:“io_113”,“f”:0,“c”:“{"act":0,"appear_in_popup":true,"ci":{},"cm":1,"mu":0,"pos":6,"show_time":false,"timeout":0}”,“vt”:0,“vs”:0,“tbl”:,“ct”:1695125877,“mt”:1695125877}
{“id”:3,“n”:“Fuel Tank Capacity”,“t”:“custom”,“d”:“”,“m”:“l”,“p”:“const214”,“f”:0,“c”:“{"act":1,"appear_in_popup":true,"ci":{},"cm":1,"mu":0,"pos":3,"show_time":false,"timeout":0}”,“vt”:0,“vs”:0,“tbl”:,“ct”:1695125877,“mt”:1695213070}
In “Query-1” result, values coming in “key” field of the jason is actually an id which needs to join with “Query-2”.“id” field. We are not able to join it since id field is coming as key:value pair in Query-1.
Expected output:
Please advice.
Can you clean up the second json data sample? It says not valid json
{"id":1,"n":"Device Battery","t":"custom","d":"","m":"%","p":"io_113","f":0,"c":"{"act":0,"appear_in_popup":true,"ci":{},"cm":1,"mu":0,"pos":6,"show_time":false,"timeout":0}","vt":0,"vs":0,"tbl":[],"ct":1695125877,"mt":1695125877}
{"id":3,"n":"Fuel Tank Capacity","t":"custom","d":"","m":"l","p":"const214","f":0,"c":"{"act":1,"appear_in_popup":true,"ci":{},"cm":1,"mu":0,"pos":3,"show_time":false,"timeout":0}","vt":0,"vs":0,"tbl":[],"ct":1695125877,"mt":1695213070}
Please post properly fornatted json data and please validate before posting?
Hello Yosiasz,
It’s strange that you might be getting some issues with JSON data but that is what we are receiving from the pai call. Let me finetune the response.
QUERY-1 Result:
“1”: 100,
“2”: 78.3448275857,
“3”: 214,
“4”: 32,
“5”: 1,
“6”: 23.117,
“7”: 28807.694,
“8”: -348201.3876
QUERY-2 Result:
“items”: [
“sens”: {
“1”: {
“id”: 1,
“n”: “Device Battery”,
“t”: “custom”,
“d”: “”,
“m”: “%”
“2”: {
“id”: 2,
“n”: “Fuel Level”,
“t”: “fuel level”,
“d”: “”,
“m”: “l”
“3”: {
“id”: 3,
“n”: “Fuel Tank Capacity”,
“t”: “custom”,
“d”: “”,
“m”: “l”
“4”: {
“id”: 4,
“n”: “Fuel Tank Temperature”,
“t”: “temperature”,
“d”: “”,
“m”: “°C”
“5”: {
“id”: 5,
“n”: “Ignition”,
“t”: “engine operation”,
“d”: “”,
“m”: “On/Off”
“6”: {
“id”: 6,
“n”: “Main Power”,
“t”: “voltage”,
“d”: “”,
“m”: “V”
“7”: {
“id”: 7,
“n”: “Odometer”,
“t”: “mileage”,
“d”: “”,
“m”: “km”
“8”: {
“id”: 8,
“n”: “Mileage (Yesterday)”,
“t”: “mileage”,
“d”: “”,
“m”: “km”
Expected Output:
Query-2 represent the master data for the sensors with sensor id (items.sens.[].id) and sensor name (items.sens.[].n). Query-1 represent the current value of the sensors. We need to join Query-1 & Query-2 using sensor ID but unfortunately we are not able to interpret id in Query-1 as a column and so we are not able to join.
Hope I am able to explain my case now.
"sens": {
"1": {
"id": 1,
"n": "Device Battery",
"t": "custom",
Etc
It might be your api is sending that but if what you post in this forun is not proper json then we have a problem helping you
Hello Yosiasz,
It is difficult to explain full JSON but let me put it very simple way so you can help.
QUERY-1 Result:
“1”: 100,
“2”: 78.3448275857,
“3”: 214,
“4”: 32,
“5”: 1,
“6”: 23.117,
“7”: 28807.694,
“8”: -348201.3876
QUERY-2 Result:
“1”: “Device Battery”,
“2”: “Fuel Level”,
“3”: “Fuel Tank Capacity”,
“4”: “Fuel Tank Temperature”,
“5”: “Ignition”,
“6”: “Main Power”,
“7”: “Odometer”,
“8”: "Mileage "
