I have tried to use Dashboard Variables only for the solution i would like to have .
( my first forum post : Dashboard Variables ) .
But i think i made it wrong, and i need to join 2 different Datasources and filter after ( the point i miss ) .
The reason for all this is we need a “Custom Business Like Description” to a “host_name , service_description tag” in influx . We cannot add this description to influxdb itself.
( Take the Description in the csv as selection to pull data from influx with the tag of host_name and service_description + time from demo3-in and demo3-out series)
To be able to reproduce i have tried to build csv Data to load into influx .
demo3-in,region=1,host_name=Hostname1,service_description=Interface1 fieldkey=12
demo3-out,region=1,host_name=Hostname1,service_description=Interface1 fieldkey=42
demo3-in,region=1,host_name=Hostname1,service_description=Interface2 fieldkey=12
demo3-out,region=1,host_name=Hostname1,service_description=Interface2 fieldkey=42
demo3-in,region=2,host_name=Hostname2,service_description=Interface1 fieldkey=22
demo3-out,region=2,host_name=Hostname2,service_description=Interface1 fieldkey=52
demo3-in,region=2,host_name=Hostname2,service_description=Interface2 fieldkey=22
demo3-out,region=2,host_name=Hostname2,service_description=Interface2 fieldkey=52
demo3-in,region=3,host_name=Hostname1,service_description=Interface3 fieldkey=32
demo3-out,region=3,host_name=Hostname1,service_description=Interface3 fieldkey=62
demo3-in,region=4,host_name=Hostname2,service_description=Interface3 fieldkey=42
demo3-out,region=4,host_name=Hostname2,service_description=Interface3 fieldkey=72
demo3-in,region=4,host_name=Hostname2,service_description=Interface4 fieldkey=42
demo3-out,region=4,host_name=Hostname2,service_description=Interface4 fieldkey=72
The 2nd query is a grafana csv query to show what it is needed ( production would be postgres ) .
cat demo.txt
Region,Description,host_name,service_description
“1”,“Line to 1”,“Hostname1”,“Interface1”
“1”,“Line to 2”,“Hostname1”,“Interface2”
“2”,“Line to 3”,“Hostname2”,“Interface1”
“2”,“Line to 4”,“Hostname2”,“Interface2”
“3”,“Line to 5”,“Hostname1”,“Interface3”
“3”,“Line to 6”,“Hostname3”,“Interface2”
“4”,“Line to 7”,“Hostname2”,“Interface3”
“4”,“Line to 8”,“Hostname2”,“Interface4”
I have added with the csv datasource a dashboard variable to select the “Description” field ( Line to x ) .
I am able to query both and i have the description field from the csv as pull down .
mix query:
query1:
SELECT mean(“fieldkey”) FROM “demo3-out” WHERE $timeFilter GROUP BY time(5m), “host_name”::tag, “service_description”::tag fill(none)
query2:
SELECT mean(“fieldkey”) FROM “demo3-in” WHERE $timeFilter GROUP BY time(5m), “host_name”::tag, “service_description”::tag fill(none)
query3 :
csv
The result query should be timeseries data from the InfluxDB + description from the csv . ( key = host_name,service_description ) , and filter by the set Dashboard Variable (description)
I have tried with transform join data by field ( inner , outa ) , but it seems not to work .
I only got it working with the 2 same datasource demo3-in and demo3-out based on time.
Thx for any help ,
Best regads, Dietmar
