Docker image grafana/grafana:11.2.6-ubuntu -
Improve security of Content Security Policy (CSP), specifically on style-src directive -
- Removing ‘unsafe-inline’ from style-src.
- Adding $NONCE to allow trusted inline styles.
What happened?
- Grafana homepage does not load correctly
- Errors reported in browser console
Improve the security of the CSP in Grafana to only allow inline styles from the same origin, or from trusted origins, avoiding such a permissive policy -
services:
grafana:
container_name: grafana
image: grafana/grafana:11.2.6-ubuntu
environment:
GF_LOG_LEVEL: “debug”
GF_SERVER_ROUTER_LOGGING: “true”
GF_SECURITY_CONTENT_SECURITY_POLICY: “true”
GF_SECURITY_CONTENT_SECURITY_POLICY_TEMPLATE: “script-src ‘self’ ‘strict-dynamic’ $$NONCE;object-src ‘none’;font-src ‘self’;style-src ‘self’ $$NONCE;img-src * data:;base-uri ‘self’;connect-src ‘self’ grafana.com ws://$$ROOT_PATH wss://$$ROOT_PATH;manifest-src ‘self’;media-src ‘none’;form-action ‘self’;”
ports:
- 3000:3000 -
Refused to apply inline style because it violates the following Content Security Policy directive: “style-src ‘self’ ‘nonce-Nq1nWrsBrlbkEJJ+uquwyQ’”. Either the ‘unsafe-inline’ keyword, a hash (‘sha256-4bik+wU2/aEsu/1U9IyPEl3/GOGdZ1NrCOY2OPv3Ztc=’), or a nonce (‘nonce-…’) is required to enable inline execution.
Configure security hardening | Grafana documentationI would appreciate any help or suggestions to resolve this issue, especially if someone has done something similar or knows the correct way to do it.
In addition to the previous report, upon reviewing the operation of the script-src directive, it generally works; however, it fails with some plugins. For example:
Infinity Datasource
yesoreyeram-infinity-datasource plugin failed
EvalError: Refused to evaluate a string as JavaScript because ‘unsafe-eval’ is not an allowed source of script in the following Content Security Policy directive: “script-src ‘self’ ‘strict-dynamic’ ‘nonce-ljiAwTgM2c1OIJAboRugNg’”.
Bussiness Text
Business Charts
ECharts Execution Error
How can I adjust the directive to be more secure and not so permissive when adding ‘unsafe-eval’?
Can anyone help or guide me?
