I am trying to get my IIS logs into loki. I want the log timestamps to be used as the timestamp passed to loki. Here is my promtail config:
scrape_configs:
- job_name: pmsi-iis
static_configs:
- targets: [localhost]
labels:
job: pmsi-iis
__path__: /var/log/pmsi-iis/*.log
pipeline_stages:
- drop:
expression: '^#'
- regex:
expression: '^(?P<timestamp>\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2})'
- timestamp:
source: timestamp
format: '2006-01-02 15:04:05'
I don’t get any errors in the promtail log. I actually see this:
level=debug ts=2025-08-26T23:37:34.106213223Z caller=regex.go:132 component=file_pipeline component=stage type=regex msg="extracted data debug in regex stage" extracteddata="map[filename:/var/log/pmsi-iis/test37.log job:pmsi-iis timestamp:2025-08-25 00:00:06]"
Here is the log data:
2025-08-25 00:00:08 10.35.65.127 GET /api/pms/fm/faxes/queues/93/faxes/ include=document+document.mediaType+metadata.locked.byUser+notes+priority+source&filter=metadata.canceled.timestamp+eq+null&group=metadata.locked.byUser.id%20eq%20%277503%27&top=25 443 - 10.35.65.117 Mozilla/5.0+(Windows+NT+10.0;+Win64;+x64)+AppleWebKit/537.36+(KHTML,+like+Gecko)+Chrome/139.0.0.0+Safari/537.36+Edg/139.0.0.0 https://essette.prospectmedical.com/app/ 200 0 0 2395
The problem is that when I go to Grafana and query loki I don’t see any log data. I made sure the time range is set to include 2025-08-25.
When I take out the timestamp section in the config the log data shows up in Loki, but has the timestamp when it was injested, not from the log.
What is wrong with my config?
