hello,
8.4 -
I want to disable some queries of the same panel according to $variable. -
I create a variable: or/and, and the query example: true $variable up. -
What happened?
When I switch to and, grafana didn’t show the result of PromQL query, but it executed this query. -
I hope that grafana did not show the result and did not execute this PromQL query.
