I write a k6 extension, and want to display logs controller by k6.
i.e.
# show info logs
./k6 run
# show debug logs
./k6 run -v
How can I do this in my extension or modules.Register?
i.e.
# show info logs
./k6 run
# show debug logs
./k6 run -v
Hi @Harris_1!
If I understand correctly, you want to write debug and info logs in your extension.
If we take this extension as an example: JavaScript Extensions
You can write into the IsGreater(a, b int) function on the line 54 the following:
c.vu.State().Logger.Debug("This is a debug log")
c.vu.State().Logger.Info("This is an info log")
Does this answer help you?
Thanks for your reply, seems ok for me.
Certainly! To access *state.GlobalState.Logger in an extension, ensure it’s properly exposed or accessible. If it’s part of a global state, use the appropriate context or API provided by the extension framework. Double-check the extension documentation for explicit guidance on accessing the logger within your extension code. If the logger isn’t directly accessible, consider creating a helper function or exposing it via an extension API to make it available where needed. Always adhere to best practices and security considerations outlined by the extension framework.
package state
import (
“go.uber.org/zap”
// GlobalState holds the global logger instance.
type GlobalState struct {
Logger *zap.Logger
var Global *GlobalState
func init() {
// Initialize the global state and logger
logger, _ := zap.NewProduction()
Global = &GlobalState{
Logger: logger,
