I am trying to add the Prometheus data source to use Prometheus behind Google Cloud Identity-Aware Proxy (IAP). This means that every request sent to Prometheus needs to carry additional info to prove the identity. This can be done either by sending Authorization Bearer tokens in headers (server access) or by providing tokens from cookies (browser access). I decided to set up browser access and make Grafana use existing IAP-related cookies when sending requests to IAP-protected Prometheus, but I failed because it seems that Grafana JS requests don’t use cookies.
With the GCP Support help, I have found out that this might be the cause:
Once the session on
target_domainis established, the developer needs to enable credentials to be sent in the request. By default, JavaScript methods don’t attach cookies to requests. To enable credentials in the request, requests sent with an XMLHttpRequest
object need thewithCredentialsproperty set to true, while requests sent with the Fetch API need thecredentialsoption set toincludeorsame-origin.
Is there an option to configure or workaround this?
Thanks in advance.
Regards,
Milan
