Is it possible to modify a value in all queries at same time?
Hello, I have changed the postgre table name on grafana source so I have to update all queries used in all panel of my dashboards, is there a way to update all queries at the same time?
or to access the queries without having to navigate througth the dashboards ?
Save the dashboards as JSON, edit, then re-import?
Antony.
Or use grafana api to modify them all
