Hello! the requirement is to send different levels of email alerts for example; if the disk usage is 80% as a WARNING alert, if it exceeds above 90% as CRITICAL and so on.
Can I please know if there is any possibility to do so, without creating separate panels for each scenario. It is true that we can define several alert rules for the same panel but still the message body would be the same I guess.
It would be even great if we could handle and maintain different email templates. I would like to have an insight of the possibility to achieve the above requirement.
Thanks in advance!
