Internal variable for current dashboard url
I try to configure a table panel with rendered value as link. My goal is when you click on link, it updates current dashboard variable.
To do this, I want to pass variable in current dashboard url. Unfortunately I did not find if an internal variable containing current url (or current dashboard uid) exists? I have to put the dashboard uid in the link. Which seems not elegant.
Do you have an idea?
I have the same question. Can anyone confirm whether this is possible to access the current URI or URL?
In my case, I have many panels on many dashboards. If I hard code the full URL into a dashlink (yes, functionally this works) but then subsequently change the dashboard name or copy the panel to another dashboard, the links become invalid.
There is a special variable ${__cell_x} to select the table column. I am looking for a special variable - including syntax - to access the current URI.
Any thoughts?
I know this is late but I was looking for this answer and after finding no help experimented with it myself. I found that ${__dashboard.uid} substitutes in the current dashboards uid. I can’t find this in the documentation at all but it’s working now. It may break in the future so test it out. Hope this helps someone else (or future me)!!!
Working for me on Grafana v8.3.6
I’m using it for Data Links:
…/d/${__dashboard.uid}/${__dashboard}?var-cir=all&time=${__data.fields.timeEpoch}&time.window=172800000
