Installing grafana/graphite on raspberry pi
Grafana 9.4.7
Graphite 1.1.3-6
Raspberry pi 2023-02-21
Connect grafana to a graphite data source
From the dashboard
  • What happened?
My graphite instance is running on graphite.local on port 80 (well, nginx fronting it). When I set the graphite datasource URL to ‘http://graphite.local/’ and hit “Save and test”, it comes back with
<!doctype html> <html lang=en> <title>415 Unsupported Media Type</title> <h1>Unsupported Media Type</h1> <p>Did not attempt to load JSON data because the request Content-Type was not &#39;application/json&#39;.</p>
Also, when I look in the grafana logs, this is what I see:
logger=cleanup t=2023-04-27T00:08:43.548841837+01:00 level=info msg="Completed cleanup jobs" duration=38.444037ms
logger=context userId=1 orgId=1 uname=admin t=2023-04-27T00:08:47.612348259+01:00 level=info msg="Request Completed" method=POST path=/api/datasources/proxy/uid/pXD6pis4z/render status=415 remote_addr=192.168.1.201 time_ms=210 duration=210.381553ms size=215 referer=http://grafana.local:3000/datasources/edit/pXD6pis4z handler=/api/datasources/proxy/uid/:uid/*
I don’t see any mention of it trying to reach http://graphite.local. I also don’t see the datasource file showing up in /etc/grafana/provisioning/datasources
I suppose I was expecting either for it to work, or to have some sort of error which I could troubleshoot.
See above
that error is a red herring the issue is elsewhere. for example let us say I have a POST rest api that expects one of the parameter [FromBody] DataInput and I made a call to this endpoint but omit DataInput you will get the same error
what if you just used the following
spun up graphite using podman, fed it some data via python
You’re right. The problem is that I had set up graphite-api, and the plugin was expecting graphite-web (although it would be nice if it said as much somewhere, given that there are two different ways of setting up graphite).
Anyway, I’ve given up on graphite, I installed prometheus instead, and it all just worked!
Thanks for the response, though!
-Jack
