Install Grafana on Podman instead of docker
Greetings,
Trying to spin this pod up using podman instead of docker. Can someone with docker try it for me and see if it works?
version: "3"
networks:
  loki:
services:
  loki:
    image: grafana/loki:2.8.0
    ports:
      - "3101:3100"
    command: -config.file=/etc/loki/local-config.yaml
    volumes:
      - ./loki-config.yml:/etc/loki/loki-config.yml
    networks:
      - loki
  promtail:
    image: grafana/promtail:2.8.0
    volumes:
      - promtail:/var/log
      - ./promtail-local-config.yaml:/etc/promtail/docker-config.yaml
    command: -config.file=/etc/promtail/docker-config.yaml
    networks:
      - loki
  grafana:
    environment:
      - GF_PATHS_PROVISIONING=/etc/grafana/provisioning
      - GF_AUTH_ANONYMOUS_ENABLED=true
      - GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
    entrypoint:
      - sh
      - -euc
        mkdir -p /etc/grafana/provisioning/datasources
        cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
        apiVersion: 1
        datasources:
        - name: Loki
          type: loki
          access: proxy
          orgId: 1
          url: http://loki:3100
          basicAuth: false
          isDefault: true
          version: 1
          editable: false
        EOF
        /run.sh
    image: grafana/grafana:latest
    ports:
      - "3001:3000"
    networks:
      - loki
  flog:
    image: mingrammer/flog
    command: -f json -d 1s -l
    networks:
      - loki
volumes:
  promtail:
  sock:
