I trying to ingest logs from Datomic database. But it uses the EDN pattern, example below:
2024-10-17 15:19:03.060 INFO default org.eclipse.jetty.util.log - Logging initialized @1902ms to org.eclipse.jetty.util.log.Slf4jLog
2024-10-17 15:19:03.346 INFO default datomic.slf4j.bridge - SLF4J Bridge installed
2024-10-17 15:19:03.353 INFO default datomic.transactor - {"datomic.metricsCallback" datomic-exporter.metrics/ingest-metrics, :tid 20, "datomic.printConnectionInfo" true, "datomic.prefetchProbes" true, "datomic.memcachedLib" "spy", "datomic.txTimeoutMsec" 10000, "datomic.indexWorkDir" #object[java.io.File 0x47d720e "./data/indexer"], "datomic.heartbeatIntervalMsec" 5000, "datomic.memoryIndexThreshold" 33554432, "datomic.s3RetryBaseDelay" 100, "datomic.dynamicIndexParallelism" false, "datomic.s3ClientExecutionTimeout" 5500, "datomic.backupBranchConcurrency" 32, "datomic.indexParallelism" 1, "datomic.localMemcachedConfigTimeoutMsec" 100, "datomic.queryPool" 32, "datomic.versionUnique" "7187", "datomic.objectCacheMax" 134217728, "datomic.allowLogOverlap" false, "datomic.externalSortPool" 4, "datomic.ddbClientExecutionTimeout" 1100, "datomic.readAheadPool" 12, "datomic.version" "1.0.7187", "datomic.ddbSocketTimeout" 900, "datomic.s3RequestTimeout" 5000, "datomic.backupUseSegsetStorage" true, "datomic.efsDeletePool" 128, :pid 92854, :event :config/properties, "datomic.dataDir" #object[java.io.File 0x61b7fef2 "./data"], "datomic.s3BackupConcurrency" 25, "datomic.s3ConnectionTimeout" 4500, "datomic.memoryIndexMax" 268435456, "datomic.ddbConnectionTimeout" 900, "datomic.s3SocketTimeout" 4500, "datomic.memcachedGetTimeoutMsec" 20, "datomic.valcachePutsPool" 4, "datomic.fileBackupConcurrency" 5, "datomic.writeConcurrency" 4, "datomic.memcachedRepairFromSpyRatio" 0.1, "datomic.useIndexArrayCaches" true, "datomic.localMemcachedAutoDiscovery" false, "datomic.s3MaxRetries" 9, "datomic.podGcDelayMsec" 60000, "datomic.memcachedExpirationDays" 30, "datomic.defaultPartition" :db.part/user, "datomic.indexIOParallelism" 100, "datomic.readConcurrency" 8, "datomic.efsWritePool" 128, "datomic.indexDirScale" 1, "datomic.memcachedAutoDiscovery" false, "datomic.cloudwatchName" "Transactor", "datomic.peerConnectionTTLMsec" 10000, "datomic.memcachedConfigTimeoutMsec" 100, "datomic.deleteConcurrency" 1, "datomic.exciseIOParallelism" 100, "datomic.ddbRequestTimeout" 1000, "datomic.buildRevision" 7187, "datomic.prefetchConcurrency" 5}
2024-10-17 15:19:03.558 INFO default datomic.process-monitor - {:event :metrics/initializing, :metricsCallback datomic-exporter.metrics/ingest-metrics, :phase :begin, :pid 92854, :tid 20}
2024-10-17 15:19:04.058 INFO default datomic.log-gc - {:gcName "G1 Young Generation", :gcAction "end of minor GC", :gcCause "Metadata GC Threshold", :event :gc, :duration 8, :pid 92854, :tid 13}
2024-10-17 15:19:05.092 INFO default datomic.log-gc - {:gcName "G1 Young Generation", :gcAction "end of minor GC", :gcCause "G1 Evacuation Pause", :event :gc, :duration 10, :pid 92854, :tid 13}
2024-10-17 15:19:05.604 INFO default datomic.process-monitor - {:event :metrics/initializing, :metricsCallback datomic-exporter.metrics/ingest-metrics, :msec 2040.0, :phase :end, :pid 92854, :tid 20}
2024-10-17 15:19:05.604 INFO default datomic.process-monitor - {:metrics/started datomic-exporter.metrics/ingest-metrics, :pid 92854, :tid 20}
2024-10-17 15:19:05.605 INFO default datomic.domain - {:event :cache/create, :cache-bytes 134217728, :pid 92854, :tid 30}
2024-10-17 15:19:05.609 INFO default datomic.process-monitor - {:GcPauseMsec {:lo 8, :hi 10, :sum 18, :count 2}, :AvailableMB 725.0, :ObjectCacheCount 0, :event :metrics, :pid 92854, :tid 30}
2024-10-17 15:19:05.611 INFO default common-metrics.components.prometheus - {:line 67, :cid "DEFAULT", :log :starting-prometheus-reporter}
2024-10-17 15:19:05.629 INFO default datomic.lifecycle - {:tid 32, :username "XwBRRa99KZhW7EhMVaj01SD5SrJvPqvprZZG9Xes9Sk=", :port 4334, :rev 73468, :host "localhost", :pid 92854, :event :transactor/heartbeat, :version "1.0.7187", :timestamp 1729189145619, :encrypt-channel true}
2024-10-17 15:19:05.629 INFO default datomic.transactor - {:event :transactor/start, :args {:log-dir "log", :protocol :dev, :rest-alias "dev", :memory-index-max "256m", :port 4334, :memory-index-threshold "32m", :data-dir "./data", :object-cache-max "128m", :host "localhost", :metrics-callback "datomic-exporter.metrics/ingest-metrics", :version "1.0.7187", :encrypt-channel true}, :pid 92854, :tid 20}
2024-10-17 15:19:05.688 INFO default o.a.activemq.artemis.core.server - AMQ221000: live Message Broker is starting with configuration Broker Configuration (clustered=false,journalDirectory=./data/artemis,bindingsDirectory=data/bindings,largeMessagesDirectory=data/largemessages,pagingDirectory=data/paging)
I’m trying to use with promtail, but with little success. How would be a way to ingest this type data (with nested info at EDN) to loki to be able to search? Any tips or direction?
I could not find any thing =/
