After updating my dockers to 3.2.2 i started getting this error
ERRO[0010] InfluxDB: Couldn't write stats
error="{\"code\":\"unauthorized\",\"message\":\"unauthorized access\"}"
Any help would be appreciated.
Thanks
Kiran
Thanks
Kiran
This might be because you’re using InfluxDB v2, with which k6 is currently incompatible. If that’s the case, you can either downgrade to InfluxDB v1.8 and wait for us to close this issue, or try to use the xk6 extension for InfluxDB v2 that this user made.
You just specify the version after the image name, like this: influxdb:1.8. Here’s how we’ve done it in our docker-compose file.
It worked ! thanks a lot.
-Kiran
Do we know if nfluxDB v2 and k6 are compatible yet?
Is xk6 the only option to use k6 w/ influxDB v2?
