Infinity datasource -Dashboard Designing -online CSV
This is regarding the infinity datasource CSV online feasibility for the combination of columns with different conditions on single panel have CSV online with following example of data , where I would like to count the value based on the result condition,
When I am trying with Same column and different condition under results set, no results displaying .
Input
region Env
Switzerland Prod
EMEA Prod
Americas Prod
Switzerland Prod
Switzerland Prod
Asia Pacific Prod
Americas Prod
Switzerland Prod
EMEA Prod
Switzerland Non-Prod
Americas Non-Prod
EMEA Non-Prod
Asia Pacific Non-Prod
Output should be something like below
Region Prod(count) Non-Prod(count)
Americas 10 10
Asia Pacific 10 20
EMEA 10 20
Switzerland 10 30
Grand Total 40 80
is there a way to get the count of values based on condition for multiple columns or single column in the single panel either with pie chartm,Bar Gauge,Bar chart and so…
using UQL
parse-csv
| pivot count(), "region", "Env"
Thank you for the suggestion . I have tried to use the same but unfortunately ,it gives me the error.
My input is a CSV which is on different server and accessing via URL.
in Linux servers, it stored as comma separated as
and when Opening CSV
Type =UQL and source=URL
Type =CSV and parser=UQL source=URL
both types are giving Error message is “error applying uql query !”
change uql to csv and see if you get any data
UQL docs available in UQL
What I see is that you have incorrect syntax. count method in query require parameter. Like count("id")
