I query multiple times, but the results returned each time are inconsistent
auth_enabled: false
server:
http_listen_port: 3100
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
chunks:
prefix: chunks_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /a8root/work/service/loki-new/boltdb-shipper-acitve
cache_location: /a8root/work/service/loki-new/boltdb-shipper-cache
cache_ttl: 24h
shared_store: filesystem
filesystem:
directory: /a8root/work/service/loki-new/loki/chunks
compactor:
working_directory: /a8root/work/service/loki-new/boltdb-shipper-compactor
retention_enabled: true
delete_request_cancel_period: 168h
deletion_mode: filter-and-delete
limits_config:
query_timeout: 5m
max_cache_freshness_per_query: '10m'
split_queries_by_interval: 1h
enforce_metric_name: false
reject_old_samples: true
max_query_series: 10000
max_query_parallelism: 32
per_stream_rate_limit: 500MB
per_stream_rate_limit_burst: 1000MB
ingestion_rate_strategy: local
ingestion_rate_mb: 150
ingestion_burst_size_mb: 200
allow_deletes: true
frontend:
log_queries_longer_than: 5s
compress_responses: true
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 3
final_sleep: 0s
querier:
tail_max_duration: 10m
extra_query_delay: 5s
engine:
timeout: 30m
max_look_back_period: 300s
memberlist:
join_members:
{{$JOIN_MEMBERS}}
abort_if_cluster_join_fails: false
bind_port: 7946
chunk_store_config:
max_look_back_period: 168h
table_manager:
retention_deletes_enabled: true
retention_period: 168h
