Running Loki v2.9.0 and pushing nginx logs with Promtail. Having two indentical request right after each other seems to make one of them go missing. I some cases if there are more than 5 lines sent, 2-3 lines are in Loki but the rest are not.
For example the nginx logs below.
10.20.4.212 - - [12/Jan/2024:16:01:02 +0000] "GET /api/live/ws2 HTTP/1.1" 404 24 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" "-"
These end up as the following in Grafana
The Promtail config is simply just parsing the timestamp from Nginx.
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /etc/promtail/positions.yaml
clients:
- url: http://localhost:3100/loki/api/v1/push
external_labels:
hostname: tools
scrape_configs:
- job_name: nginx
pipeline_stages:
- regex:
expression: "^.* - - \\[(?P<time>\\w{2}\\/\\w{3}\\/\\w{4}:\\w{2}:\\w{2}:\\w{2} [+-]\\w{4})\\].*"
- timestamp:
source: time
format: "02/Jan/2006:15:04:05 -0700"
static_configs:
- targets:
- localhost
labels:
job: nginx
__path__: /var/log/nginx/*.log
I do understand that one solution to this is to append a more exact timestamp to the nginx log lines but I feel like this should not need to be a problem. I have also tried to set increment_duplicate_timestamp: true in the Loki config.
Any help much appreciated.
