Hi everyone and thank you in advance for your feedback,
I need to migrate my plugin repository from GitHub to GitLab and I would like to know if it’s possible.
Could it be possible to build a release of a plugin or create a plugin using GitLab instead of GitHub?
Is there a .gitlab-ci.yml file equivalent to the ci.yml and release.yml files for the automated workflow?
Thank you again for you help.
yosiasz
November 15, 2023, 4:15pm
2
Welcome @frankroos
your question is more gitlab related than grafana. But that said here are some steps you can try
academo
November 16, 2023, 12:45pm
3
Hi @frankroos we currently only offer some templates for release for github actions. The steps are simple and you can try to reproduce them in gitlab CI solution
Thank you for you feedback @yosiasz .
I already know how to create a project. I’m looking for some CI/release templates to use with GitLab.
Thank you @academo .
I will try to reproduce ci.yml and release.yml for GitLab.
