12.0 - What are you trying to achieve?
- i have a country column in table, with 2 letter country ISO 3166-1 alpha-2 codes
i want to add flag emojis of every country in grafana table cell, is it possible? - How are you trying to achieve it?
directly pasting unicode emojis into text field is not rendering the flag emoji - What happened?
for FR(France), it is just showing as : ‘FR’ , instead of flag emoji. I tried to copy emojis from other websites like emojipedia - What did you expect to happen?
expected a flag emoji to be displayed. like :
- Can you copy/paste the configuration(s) that you are having problems with?
SELECT
countrycode_ as COUNTRY,
SUM(event_count) AS LAUNCHES,
FROM ‘my-table’
Here i want to add another column with flag emojis corresponding to every country.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- nope, it is just not rendering.
- Did you follow any online instructions? If so, what is the URL?
- nope, just asked ChatGPT and it said it is possible, but i’m still unable to do it
Also, i want to add full name of country in another column beside 2 letter country codes, any help ?
Thanks for you time ![]()
