Hello grafana community,
I’ve only been dealing with the topic of Iobroker and Grafana for a few months, but I find the whole thing very exciting because there are countless possible applications.
When implementing moisture monitoring, however, I reach my limits, you may be able to help me.
I want to monitor a room with a temperature and humidity sensor.
Programming a panel with the historical values in Grafana is no problem.
I would show the whole thing in an HX diagram.
But I can’t do that.
Is there a plugin for an HX diagram?
Can I integrate the HX diagram as a background image?
Thank you for your help !
Andreas
