Hi ![]()
I am getting a lot of http_req_failed…: 66.98% ✓ 537704.
How can I dig deeper and find out what error code they are issuing, why does K6 only gives you a total number and percentage?
Would it be possible to get more details?
I used k6 run --http-debug=full script.js but it did not help.
✗ status was 200
↳ 33% — ✓ 265025 / ✗ 537704
checks.........................: 33.01% ✓ 265025 ✗ 537704
data_received..................: 131 MB 75 kB/s
data_sent......................: 87 MB 50 kB/s
http_req_blocked...............: avg=16.98µs min=198ns med=728ns max=70.5ms p(90)=1.13µs p(95)=1.26µs
http_req_connecting............: avg=2.16µs min=0s med=0s max=26.8ms p(90)=0s p(95)=0s
http_req_duration..............: avg=537.28ms min=848.36µs med=3.75ms max=34.02s p(90)=1.05s p(95)=2.3s
{ expected_response:true }...: avg=791.85ms min=6.6ms med=170.95ms max=16.6s p(90)=2.5s p(95)=3.18s
http_req_failed................: 66.98% ✓ 537704 ✗ 265025
http_req_receiving.............: avg=11.58ms min=10.64µs med=137.53µs max=4.01s p(90)=3.37ms p(95)=91.75ms
http_req_sending...............: avg=301.53µs min=35.29µs med=133.79µs max=102.69ms p(90)=414.11µs p(95)=779.38µs
http_req_tls_handshaking.......: avg=13.21µs min=0s med=0s max=68.53ms p(90)=0s p(95)=0s
http_req_waiting...............: avg=525.4ms min=0s med=3.12ms max=34.02s p(90)=983.51ms p(95)=2.27s
http_reqs......................: 802729 459.824411/s
iteration_duration.............: avg=1.53s min=1s med=1s max=35.02s p(90)=2.06s p(95)=3.3s
iterations.....................: 802729 459.824411/s
vus............................: 115 min=4 max=1200
vus_max........................: 1200 min=1200 max=1200
