Hi, I’m a bit confused by the output I get from k6.
There is a bunch of Request Failed warnings in the log below but in the results it stated that http_req_failed................: 0.00%. How can it be 0%?
execution: local
script: test.js
output: -
scenarios: (100.00%) 1 scenario, 500 max VUs, 3m30s max duration (incl. graceful stop):
* default: Up to 500 looping VUs for 3m0s over 3 stages (gracefulRampDown: 30s, gracefulStop: 30s)
WARN[0141] Request Failed error="context deadline exceeded"
WARN[0142] Request Failed error="context deadline exceeded"
WARN[0144] Request Failed error="context deadline exceeded"
WARN[0146] Request Failed error="context deadline exceeded"
WARN[0147] Request Failed error="context deadline exceeded"
WARN[0148] Request Failed error="context deadline exceeded"
WARN[0149] Request Failed error="context deadline exceeded"
WARN[0150] Request Failed error="context deadline exceeded"
WARN[0152] Request Failed error="context deadline exceeded"
WARN[0154] Request Failed error="context deadline exceeded"
WARN[0155] Request Failed error="context deadline exceeded"
WARN[0156] Request Failed error="context deadline exceeded"
WARN[0157] Request Failed error="context deadline exceeded"
WARN[0159] Request Failed error="context deadline exceeded"
WARN[0162] Request Failed error="context deadline exceeded"
WARN[0164] Request Failed error="context deadline exceeded"
WARN[0166] Request Failed error="context deadline exceeded"
WARN[0167] Request Failed error="context deadline exceeded"
WARN[0168] Request Failed error="context deadline exceeded"
WARN[0169] Request Failed error="context deadline exceeded"
WARN[0172] Request Failed error="context deadline exceeded"
WARN[0174] Request Failed error="context deadline exceeded"
WARN[0176] Request Failed error="context deadline exceeded"
WARN[0177] Request Failed error="context deadline exceeded"
WARN[0191] Request Failed error="context deadline exceeded"
running (3m14.1s), 000/500 VUs, 8763 complete and 27 interrupted iterations
default ✓ [======================================] 000/500 VUs 3m0s
data_received..................: 4.1 GB 21 MB/s
data_sent......................: 15 MB 78 kB/s
http_req_blocked...............: avg=186.04ms min=34.57ms med=165.69ms max=2.71s p(90)=282.68ms p(95)=331.31ms
http_req_connecting............: avg=96.47ms min=15.06ms med=78.38ms max=2.23s p(90)=163.84ms p(95)=196.15ms
http_req_duration..............: avg=3.48s min=389.01ms med=1.87s max=59.92s p(90)=5.89s p(95)=10.93s
{ expected_response:true }...: avg=3.48s min=389.01ms med=1.87s max=59.92s p(90)=5.89s p(95)=10.93s
http_req_failed................: 0.00% ✓ 0 ✗ 8763
http_req_receiving.............: avg=3s min=66.27ms med=1.42s max=59.57s p(90)=5.41s p(95)=10.48s
http_req_sending...............: avg=85.53µs min=38µs med=78µs max=921µs p(90)=120µs p(95)=139µs
http_req_tls_handshaking.......: avg=89.45ms min=17.86ms med=69.42ms max=2.27s p(90)=155.47ms p(95)=193.75ms
http_req_waiting...............: avg=481.65ms min=217.45ms med=420.51ms max=12.97s p(90)=754.43ms p(95)=852.12ms
http_reqs......................: 8763 45.140969/s
iteration_duration.............: avg=3.66s min=434.94ms med=2.08s max=1m0s p(90)=6.1s p(95)=11.08s
iterations.....................: 8763 45.140969/s
vus............................: 1 min=1 max=500
vus_max........................: 500 min=500 max=500
