hi ,
I trying to integrate Webseal SSO to perform authentication with grafana. According to the grafana “Grafana Authproxy” tutorial, do i still need to run a apache webserver in between webseal and grafana?
http://docs.grafana.org/tutorials/authproxy/
regards
Does not need to be apache but any reverse proxy that can do the authentication and add the HTTP header.
was wondering which authentication to be used in the case? I was trying to get [auth.proxy] to work, with the following setting
[auth.proxy] enabled = true header_name = http_username header_property = username auto_sign_up = true ldap_sync_ttl = 60 whitelist =
am i using the right authentication?
