Hi, does anyone know if it is possible to use a Prometheus metric value that happens to be a timestamp as the timestamp when that metric is graphed in Grafana?
Our metric returns a value such as 1690396973. We can convert this into a time value by changing the unit to date/time, however I am unable to see a way to use this returned value as the primary timestamp in the panel.
This is the best I could come up with, where the returned metric value time is on the Y axis and the native Prometheus timestamp is on the X axis. We would really like to be able to use the results of that query as the timestamp on the X axis and disregard the Prometheus timestamp entirely. Is something like that possible?
My query currently is something like this:
test_metric{label=“label”} * 1000
@kvsmoove Is your issue resolved? Please let me know how did you achieve that? Thanks in advance.
It was not able to be resolved, we ended up moving to a different data source for that product that had strict timestamp requirements.
Hi, you could theoretically go into transformations and do:
but the problem is - you don’t have anything to plot (no numbers). I can hardly imagine such a scenario (as long as you don’t need “that thing happened here”, where you Add field from caluclation to just mark the point).
Please, if you can help me, I was able to display the first time the condition occurred (any server’s utilization rate reaches above 85%) using functions such as
min_over_time(), timestamp()
I was able to display the time correctly as you can see, but I notice that the time and date increases by a minute with each refresh and this weakens the accuracy of the date and I want to prove the value of the date, can you please help me?
