Grafana v9.4.7 -
I need to understand how to use themimirtoolcommand to analyze alerts defined into my Grafana instance. I can analyze dashboards in order to get Prometheus metric names that are used there with themimirtool analyze grafanacommand, but I do not see how to also analyze Grafana alerts. -
By using themimirtoolcommand. I’m able to export alerts into a Yaml file, but it seems there is not way to pass that file tomimirtoolto get the job done (or I haven’t found it at least) -
What happened?
Unfortunately nothing -
I would like to have the possibility to analyze Grafana alert rules withmimirtool -
N/A -
N/A -
N/A
Hi @paoloyx
To resolve your issue, please refer to the official documentation below:
