If I understand the offer of the free tier correctly, it also offers Loki up to a total of 50GB? Is that right? How can I then use Loki e.g. what is the endpoint onto where logs have to be sent?
Hi @papanito - thatās correct, the free tier currently includes 50GB of logs with 14 day retention (30 days on the Pro plan).
The following guide should help you get started: Gathering logs from a Linux host using Promtail | Grafana Labs
@papanito it looks like you need to enable the new free tier on your existing account:
- Go to the gear: Configuration ā Users
- Click on āManage Users on Grafana.comā which will take you to your management portal.
- Up top, click āStart Free Trialā. This will provision your full Grafana Cloud Stack for the free tier, we just provide you with 14 days to play around with all the Pro features and then automatically move you to the free plan.
If for some reason that doesnāt work, log into grafana.com and open a support ticket and weāll help you out.
thanks a lot @daviddorman starting a free trial helped. In addition then configs were automatically created so no manual configuration
I have the same problem.
Both
https://grafana.com/docs/grafana-cloud/logs/collect-logs-with-agent/
and
say
Open a different browser tab and open Grafana Cloud. In this tab:
- In the side menu, from Onboarding (looks like a lightning bolt) select Walkthrough
but the lightning bolt is called āIntegrations and Connectionsā.
It looks like Grafana Cloud comes preloaded,
in the explore > drop down I can see
āgrafanacloud--logsā, -traces, etc.
To get this working I did:
- Click on āManage Users on Grafana comā which will take you to your management portal.
- Under Grafana Cloud click my link
- In the list of panels found the āLokiā one and click āDetailsā
This gave me the instructions and connection details to wire everything up.
Thanks for sharing your approach @barrietreloar! Looks like those docs need some updating since weāve changed the menu navigation naming a bit. Iāll share that observation with the Docs team!
