How to use Grafana variables efficiently in Flux Queries
Grafana v9.5.1 . Influxdb 2.71, Ubuntu 20
How to use Grafana variables efficiently in Flux Queries in a time series panel with a variable to toggle between hostnames in the queries.
The base query is straight from the Influxdb explorer to retrieve server data.
from(bucket: “servermonitoring1”)
|> filter(fn: (r) => r[“_measurement”] == “win_proc”)
|> filter(fn: (r) => r[“_field”] == “Working_Set”)
|> filter(fn: (r) => r[“host”] == “WIN-4DI0Q3AMP8N”)
|> filter(fn: (r) => r[“instance”] == “_Total”)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: “mean”)
I modified to use a grafana variable for hostname.
|> filter(fn: (r) => contains(value: r[“host”], set: ${hostnamev:json}))
|> yield(name: “mean”)
Grafana variable ‘hostnamev’ and its query
import “influxdata/influxdb/schema”
schema.tagValues(bucket: “servermonitoring1”, tag: “host”)
When the base query with hard coded hostname at a time range setting of 1 day runs in about 1 sec.
The second query with using a variable for contains() and hostname takes 120 seconds!
As you increase the time range this get exponentially longer to where its not useful.
Is there a more time efficient means to accomplish using grafana variables in flux queries?
Welcome @onezandzeroz
I noticed your query used this…
instead of something like this:
  |> filter(fn: (r) => r["host"] == "${hostnamev}")
My typical variable query is:
import "influxdata/influxdb/schema"
schema.tagValues(
    bucket: "your-bucket",
    tag: "tag-which-you-want-as-a-variable"
Does changing to the above make any difference in the speed?
That works great. I suspected the contains() was a time intense function but not familiar enough in this environment for a better solution.
THANKS!
