How to use feature of fail( [err] ) to stop the iteration inside chaijs describe() block
expect() throws an exception inside a describe() block. pls see this code with describe()-expect()
export const options = {
vus: 1,
iterations: 1
import exec from ‘k6/execution’;
import { check, group, fail } from ‘k6’;
import { describe, expect } from ‘https://jslib.k6.io/k6chaijs/4.3.4.3/index.js’;
export default function testSuite() {
describe('first describe', () => {
    const iteration = exec.vu.iterationInScenario;
    expect(iteration, 'response status').to.equal(1);
    console.log(`passed on ${exec.vu.iterationInScenario} iteration`)
describe('second describe', () => {
    expect(iteration, 'response status').to.equal(0);
But fail( [err] ) throws an error which stops that particular iteration. See same code with group()-check()-fail()
vus: 1,
iterations: 1
group('first describe', () => {
    if(!check(iteration, { 'iteration equals' : ( ) => iteration == 1 })){
        fail('iteration is not 1')
group('second describe', () => {
    if(!check(iteration, { 'iteration equals' : ( ) => iteration == 0 })){
        fail('iteration is not 0')
I want to stop the vu iteration when any expect() fails.
How can I achieve fail([err]) functionality with describe()-expect() ?
@lucky041295
describe() + expect() works as it is intended, because describe() catches the exceptions to allow the other describe() to run. If you want to prevent the other describe() to run, you should connect the describe() functions with && as the documentation suggests
https://k6.io/docs/javascript-api/jslib/k6chaijs/describe/
vus: 1,
iterations: 1
import { describe, expect } from ‘https://jslib.k6.io/k6chaijs/4.3.4.3/index.js 1’;
