I need to generate a pie chart for the top 10 rows on a query result.
The result of the query includes a name and three values (e.g. “Bob”,”5”, “3”, “7”)
For each row I need the pie using those numbers, and displaying the name stored on the same row.
How do I do that?
To achieve your goal of generating a pie chart for each row in your query result and using the name from each row as the panel title, you can follow these steps:
Transform Your Data:
Use the "Rows to Fields" transformation to convert each row into separate fields. This will allow you to treat each row as a distinct set of data for your pie chart.
Ensure that the field containing the name (e.g., "Bob") is used as a label or part of the field name. This can be done by mapping the name field to a label in the transformation settings.
Configure the Pie Chart:
Create a pie chart panel in Grafana.
In the panel editor, select your data source and apply the transformation to ensure each row is treated as a separate field.
Set the Show option in the Value options to All values to ensure all values from each row are displayed in the pie chart.
Set the Panel Title Dynamically:
Use the Display Name option to dynamically set the panel title using the name from each row. You can use expressions like ${__field.name} or ${__field.labels.Name} to include the name in the title.
If you have mapped the name to a label, you can use ${__field.labels.YourLabelName} to display it in the panel title.
Repeat for Each Row:
Since Grafana panels typically display a single visualization, you will need to create a separate panel for each row if you want individual pie charts for each.
Alternatively, you can use a dashboard variable to iterate over the top 10 rows and dynamically update the panel based on the selected row.
By following these steps, you can create a pie chart for each row in your query result and display the name from each row as the panel title. If you have any further questions or need more detailed guidance, feel free to ask!
grot is still learning and improving, please let me know how I did by reacting below.
It sounds like there might be an issue with how the label is being applied or accessed. Here are a few things to check and try:
Verify Label Mapping: Double-check that the label "code" is correctly mapped in the transformation settings. Ensure that the field containing the name is indeed being used as a label and that the label is named "code".
Check Data Source and Transformation: Make sure that the transformation is correctly applied and that the data source is returning the expected fields. You can use the "Table View" in the panel editor to inspect the data and confirm that the label "code" is present.
Use Correct Syntax: Ensure that the syntax ${__field.labels.code} is correctly used in the Display Name field. Sometimes, even a small typo can cause issues.
Inspect the Query Inspector: Use the Query Inspector in Grafana to see the raw data being returned and ensure that the label "code" is present in the data.
Test with a Simple Example: Try creating a simple test panel with a known dataset to see if the label mapping works as expected. This can help isolate whether the issue is with the data or the configuration.
Grafana Version: Ensure that you are using a version of Grafana that supports the features you are trying to use. Sometimes, newer features might not be available in older versions.
If after these checks the issue persists, consider providing more details about your data setup and transformation configuration, so we can help troubleshoot further.
The ability to use mapped labels in the panel title using expressions like ${__field.labels.YourLabelName} is a feature that has been available in Grafana for some time. However, the specific version where this feature became stable and widely used might not be explicitly documented.
To ensure compatibility, I recommend using Grafana version 7.0 or later, as this version introduced significant improvements and features related to transformations and field options. If you are using a version older than this, consider upgrading to take advantage of the latest features and improvements.
If you are still experiencing issues with the label not appearing as expected, it might be helpful to check the release notes or documentation for the specific version you are using to confirm the availability of this feature. Additionally, ensure that your Grafana instance is up-to-date to benefit from the latest enhancements and bug fixes. If you have any more questions or need further assistance, feel free to ask!
The use of ${__field.labels.YourLabelName} is primarily designed for time series data where labels are commonly used to provide metadata about the series. However, when working with table data, the concept of labels is not directly applicable in the same way as it is with time series data.
For table data, you typically work with columns and rows, and the transformation options available in Grafana allow you to manipulate this data structure. If you want to use a specific field from a table as a panel title, you would generally need to ensure that the field is part of the data being visualized and then use Grafana's templating features to dynamically set the panel title.
If you are trying to achieve a similar effect with table data, you might need to:
Ensure the Field is Available: Make sure the field you want to use as a title is part of the data returned by your query.
Use Transformations: Apply transformations to structure your data in a way that allows you to access the desired field. For example, you might use the "Rows to Fields" transformation to convert rows into fields if that helps in accessing the data.
Dynamic Titles: Use Grafana's templating and variable features to dynamically set the panel title based on the data. This might involve using dashboard variables or other methods to extract the necessary information.
If you are still having trouble, please provide more details about your data structure and what you are trying to achieve, and I can offer more specific guidance.
To address your requirement of using a query field as a panel title in a pie chart, especially when dealing with table data that doesn't have a time field, here are some steps and considerations:
Data Structure and Transformation:
Since your data is organized in rows with a name and three values, you can use the "Rows to Fields" transformation to convert each row into separate fields. This will allow you to treat each row as a distinct dataset for your pie chart.
Dynamic Panel Titles:
For table data, the ${__field.labels.YourLabelName} syntax might not work as expected because it's primarily used for time series data. Instead, you can use Grafana's templating features to dynamically set the panel title.
You can create a dashboard variable that captures the name field and use this variable in the panel title. For example, if you create a variable called Name, you can set the panel title to ${Name}.
Creating the Pie Chart:
In the panel editor, select your data source and apply the necessary transformations to ensure each row is treated as a separate field.
Iterating Over Rows:
If you continue to face issues, please provide more details about your data setup and transformation configuration, and I can offer more specific guidance. Additionally, ensure that your Grafana version supports the features you are trying to use, as some functionalities might vary between versions.
The table rows are generated dynamically by limiting a query to the first 10 values. How do I create a variable from the query after applying the transformations?
Can I post the panel JSON?
Certainly, posting the panel JSON can be very helpful for troubleshooting and providing more specific guidance. It allows us to see exactly how your data and transformations are configured, which can help identify any issues or suggest improvements.
Regarding creating a variable from the query after applying transformations, Grafana doesn't directly support creating variables from transformed data within a panel. However, you can achieve similar functionality by using dashboard variables and query options. Here's a general approach:
Create a Dashboard Variable:
Go to your dashboard settings and create a new variable.
Use a query to populate this variable with the names or identifiers you want to use. This query should be able to return the distinct names or identifiers you need.
Use the Variable in Your Panel:
In your panel, you can use this variable to dynamically filter or display data. For example, you can use the variable in your query to filter the data based on the selected value.
Use the variable in your panel title to dynamically display the selected name or identifier. For example, if your variable is called Name, you can set the panel title to ${Name}.
Iterate Over Rows:
If you want to create separate panels for each row, you can duplicate the panel and set each one to a different value of the variable.
If you provide the panel JSON, I can offer more specific advice based on your current setup. Feel free to share it here!
