How to transform queries from different datasource (Mixed)
    I have 2 graphite data source (active and backup). I’m trying to create a Mixed datasource and getting the data from both the DS and provide as a single panel.The reason why we are doing this is datasource 1 was not available for sometime, so if we select DS1 it will show a gap. So we want to get the data from both DS and merge them.
    Mixed Mode.
  • What happened?
    for example here is the query
    groupByNode(com.node.vm01.cpu*.idle, 4, ‘sum’) from DataSource 1
    groupByNode(com.node.vm01.cpu*.idle, 4, ‘sum’) from DataSource 2
when it renders in graana it shows both the output as expected. But the legends shows twice as they are 2 different queries . want to merge both of them into single. for example it returns for cpu-0 twice and i want to merge them both to single cpu-0.
Have you tried experimenting with the merge transformation?
