I have my docker-compose micro-apps/redis.yml at develop · xmlking/micro-apps · GitHub to install plugins via GF_INSTALL_PLUGINS
it works fine from the home network. but getting x509: certificate signed by unknown authority error when running same from behind corp proxy.
is there a way to configure skip TLS verification for plugins ?
grafana:
image: grafana/grafana:8.0.4
ports:
- "3000:3000"
environment:
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_BASIC_ENABLED=false
- GF_ENABLE_GZIP=true
- GF_USERS_DEFAULT_THEME=dark
- GF_INSTALL_PLUGINS=redis-datasource,redis-app
# defend following secrets in .env and don't commit `.env` file to git.
- REDIS_CLOUD_HOST
- REDIS_CLOUD_PASSWORD
volumes:
- ./grafana/provisioning/datasources/:/etc/grafana/provisioning/datasources/
- ./grafana/provisioning/dashboards/:/etc/grafana/provisioning/dashboards/
- grafana:/var/lib/grafana
links:
- redis
depends_on:
- redis
Error
rafana_1 | Error: ✗ Failed to send request: Get "https://grafana.com/api/plugins/repo/redis-datasource": x509: certificate signed by unknown authority
grafana_1 exited with code 1
insight_1 | error uploading: HTTPSConnectionPool(host='api.segment.io', port=443): Max retries exceeded with url: /v1/batch (Caused by SSLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)'),))
