How to skip 'empty' lines (timestamp plus TAB)
I have lines such as:
2024-02-12 11:24:43
and try:
[…] !~ `(^\t*2024-02-12 [0-9:]*\t$)
But I cannot get rid of the lines.
What do I do wrong?
Thanks
  1. Try getting rid of parenthesis (no group capture).
  2. A screenshot might be helpful.
No group capture… So it should be (?:...) ?
I think I got it: the timestamp is not part of the string being filtered!
So, excluding empty lines goes by ^\s*$
