Hi All,
Can you please, help me to display the scale min and max values in bar graph.
Further to show the threshold limits and alerts based on those limits in bar graph.
Thanks in advance
Hi All,
Thanks in advance
Hi Lochanam,
Can you explain a little better what do you want?
Hi @danielgonzalez,
When i show different parameter with different minimums and maximums it is hard to get an idea without the minimums and maximums being seen. Therefore i would like to show the minimum and maximum levels in the bar graph itself.
Further i would like to show the threshold levels in the bar graph and generate alerts based on that.
Can you help me to do this.
Thanks in advance,
Mmm this is not possible, but there is a feature that can be used, you just have to go to the legend section and activate
How is it possible to view the result of a min or max expression? It would be really nice to see it on the visualization itself.
Thanks danielgonzalez
Found them in Legend. But where are the results of the expression itself?
