How to setup Alert's in panels?
Need alert functionality for other panels like Bar chart, Stat, Gauge, Bar Gauge, Table, Pie chart, etc.
Does Grafana support alerts for this kind of panel?
Is it based on versions like Community and Enterprise versions?
If yes, could you kindly suggest how to do this?
Regards,
Nehal
Welcome @nehalwarhade25
In Grafana, you create an alert on a condition. It does not matter which type of visualization you use, so long as it is a time series.
Have you watched these two helpful videos?
Thanks for sharing these details.
Yes, I’ve gone through this document.
What I’m trying is to set alert for given Bar panel but not getting option to set alert.
Do you mean we can only set alerts for time series visualization?
Did I get you right?
