How to Set X-Axis Time Range from 9 AM to 9 PM in time series
Hi Grafana Community,
I am trying to configure a time series panel in Grafana to display data on the x-axis only from 9:00 AM to 9:00 PM. Could someone guide me on how to achieve this?
I would like the x-axis to always start at 9:00 AM and end at 9:00 PM regardless of the date range selected. Any help or guidance on how to set this up would be greatly appreciated.
Please Reply. Thank you!
What is your datasource? it is more of a datasource issue than a grafana issue.
Thank you for your response.
I am using Prometheus as my datasource. Could you please guide me on how to configure the time series panel in Grafana to display data on the x-axis only from 9:00 AM to 9:00 PM? I would like the x-axis to always start at 9:00 AM and end at 9:00 PM regardless of the date range selected.
Any help or guidance on how to set this up with Prometheus data would be greatly appreciated.
Thank you!!
given the date from the date picker how would you query and get what you need outside of grafana, 9am to 9pm that is, with some kind of prometheus querying tool.
you can check our document on how to set default time range in time series panel
Hello, just wanted to check, does my solution work for you, or are you still facing same issues Please contact me if you need any help, I will be happy to help you here.
