Grafana 8.0.3 docker with ngalert feature enabled -
Try to receive slack notification faster without any delay. -
- Enable ngalert feature
- Create an alert rule
- Add slack webhook as a contact point
What happened?
I noticed that when an alert fired, the alert message can not be sent to Slack channel immediately, it usually take few minutes. It looks like there are something like aggregation in new ngalert feature. -
I wish alert message could not sent to slack channel immediately once an alert fired -
