Hi, I’m running grafana version 5.0.0-pre1 on windows (which I built from directly from github to be able to include MSSql support). I’ve been playing around with it and installed the mtanda-histogram-panel plugin. When I tried to add one of these panels, grafana displayed an exception error. This is not the problem.
The panel never appeared, so I simply removed the plugin as it doesn’t work under windows. This worked without any problems.
The problem is that every time I open the panel to edit it or view it, I get an error saying it cannot find the histogram plugin.
So, is there any way to ‘clean’ the configuration and remove references to this plugin?
