How to read a template variable from a plugin (PanelCtrl)?
I am writing a plugin (panel). I would like to get the value of a template variable from my plugin code but I can’t figure out how to do it.
I started my plugin modifying the “Clock Panel Plugin” tutorial, here .
I need to be able to read the template variable from Javascript, inside the “updateClock()” function. Is this possible ?
Bye
Nicola
use templateSrv, and templateSrv.replace to interpolate a string
thank yo torkel,
I found the way, i write here for others who may need it:
1] put this into the contructor
this.templateSrv = $injector.get('templateSrv');
2] put something like this into the updateContent() [ keeping the
tutorial structure] . Consider I called my variable “lquery”. The
“try” is necessary.
try {
	 var templateSrv = this.templateSrv;
	 var v1 = templateSrv.replace('$lquery');
	 console.log("v1: " + v1);
  } catch (err) {
	 console.log("error: " + err);
