Hello Community,
I’m trying to calculate the average duration between POST and PUT events in InfluxDB using Flux in Grafana, but I’m encountering limitations.
Objective:
I have several POST events (POST /cases) and PUT events (PUT cases / {id}).
I want to pair each POST with the next PUT from the same user, calculate the time difference, and then calculate the total average. The user is filterable, or if I select all users, I’ll get the overall average.
This should work even if there are multiple POSTs in a row before the next PUT. In other words, my goal is to always collect the POST before the PUT and ignore all others behind it, if applicable.
Example logs:|action_type | _time|
|POST /cases | 2025-10-09 08:07:49|
|PUT /cases/123 | 2025-10-09 08:13:33|
|POST /cases | 2025-10-09 08:18:45|
|PUT /cases/456 | 2025-10-09 08:20:08|
|POST /cases | 2025-10-09 09:26:07|
|PUT /cases/789 | 2025-10-09 09:27:40|
Based on this example, the idea is to calculate the durations:
08:07:49 → 08:13:33 = 5 min 44 s
08:18:45 → 08:20:08 = 1 min 23 s
09:26:07 → 09:27:40 = 1 min 33 s
And then calculate the total average ≈ 2.89 minutes.
Current issue:
I’m trying to use join + group + sort + limit(1) in Flux, but it only captures the last POST→PUT and ignores the others.
I tried experimental.stateTracking, but I couldn’t create the pairs correctly without errors.
Question:
Is there a way in Flux/Grafana to:
Pair each POST with the next PUT sequentially for each user?
Calculate the duration between them and generate the average?
Thanks for any help or suggestions! ![]()
