I am trying to only show items when they change from a 1 value to a 0. I am using an API with the plug-in Infinity? anyone got an idea how to get that to work?
What is the JSON response received from the API you are using?
It’s pretty long but {“extensionstatus”:[{“extensionid”:“1”,“username”:“200-REDACTED”,"REDACTED:null,“regserver”:null,“useragent”:null,“lastms”:null,“customername”:“REDACTED”,“accountcode”:“REDACTED”,“online”:“1”}
there is more, but that is not really useful
To add some more info it’s a very long response and I only want to show the items that went from 1 to 0, and after they go back to 1 they leave the dashboard.
When you say you “only want to show”, there are several ways to show that…
a gap in a timeseries?
a boolean Status history?
a boolean State timeline?
a Stat panel showing 1 or 0?
Or something else? Since there are apparently only two states (1 or 0), I would think a boolean state timeline would be appropriate.
