Hello.
I am new to Grafana and all that ecosystem of related tools, like Prometheus, etc.
I need to observe the execution time of a determined query on a MSSQL server.
Unfortunately, after trying for a couple of days, I still cannot find a way on how to do it.
I took a look at the Microsoft SQL Server datasource, but again, no luck.
Could anybody help me?
Thank you and best regards.
Roberto
Grafana: 9.4.3
Ubuntu 20.04.5 LTS -
Observe the execution time of a determined query on a MSSQL server.
The query is to be executed once every hour, and I want to see a graph of query execution time in function of time of execution, for instance a period of time of 10 days. -
Through the Microsoft SQL Server data source -
What happened?
I cannot get it to work -
I’d like to see a graph with time of executin on the horizontal axis and the query execution time on the vertical axis. -
Here’s my MSSQL query as a timeseries
use MYDB
DECLARE @t1 DATETIME;
DECLARE @t2 DATETIME;
SET @t1 = GETDATE();
select * from mytable;
SET @t2 = GETDATE();
SELECT DATEDIFF(millisecond,@t1,@t2) AS time;
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Several tries, several errors… last is ‘db has not time column’
