How to monitor mysql database in grafana server
  • What happened?
Welcome @tanmoynoc
Start here: MySQL Performance Monitoring Database | InfluxData
If you are not familiar with Telegraf and/or InfluxDB, please spend time learning them. Their forum is also very active.
T have done through influxdb and prometheus but actually requirement is how to monitor database table etc. is it possible ?
Thank you
also i need to monitor network devices like router switches firewall. I have try to install snmp_exporter, after install snmp exporter service is failed. i have use latest version from official side. Please help & have you any documentation please share. Thank you.
https://sbcode.net/prometheus/snmp-exporter/
