How to monitor Gunicorn via statsD in hosted setup?
I’d like to monitor a Gunicorn server. It exports to a statsD server via UDP.
The resources I found online say that I’ll need to use statsd_exporter and send them into Prometeus. For example:
My question is how can I do this with hosted Grafana? What do I need to install locally and what on the cloud website?
The application runs inside a Docker container but I have the agent installed on the Linux host which runs Docker.
the second article is spot on. do you currently have a hosted prometheus instance?
What I have is:
  1. A linux host where I’ve installed the Linux agent from the web UI which generated the sudo command with https://raw.githubusercontent.com/grafana/agent/release/production/grafanacloud-install.sh
  2. Now I’m on this screen:
Do I have to install that agent-linux-amd64 as well, or it’s the same agent which is already installed on the host?
If so, do I just need to mix the two configs with each other?
If I understand correctly, I need to add this in my agent config, right?
  - name: hosted-prometheus
    scrape_configs:
      - job_name: node
        static_configs:
        - targets: ['localhost:9100']
    remote_write:
      - url: https://prometheus-prod-01-eu-west-0.grafana.net/api/prom/push
        basic_auth:
          username: 123456
          password: qwerty
