I am using a template variable for the filter to list down some of the string value from elasticsearch like
string1_dev_01
string1_prod_01
string2_dev_02
string2_prod_02
template variable name = version_name
column name in elastic search = version
Lucene Query : version:$version_name
when the user selects “string1_dev_01” it fetches data belongs to “string1_dev_01” from elasticsearch and display in a table panel.
But I want, when selecting either string1_dev_01 or string1_prod_01 it should fetch all data belongs to both the dev and prod.
After selected the version the string value should be modified and assigned to template variable
version_name:"string1_*_01"
Final value assign to version like
version:"string1_*_01"
Questions.
- How can I modified the selected value like
string1_*_01 - Lucene query should fetch value
- starts with -
string1_ - ends with -
_01
- starts with -
How can I achieve this in grafana? Thanks in advance.
