Grafana - v9.1.6 (92461d8d1e)
Hi @eti,
Welcome to the community support forums !!
Please review the submission template and include more details:
- What is your datasource?
- What visualization panel you are using e.g. time-series, bar chart, histogram etc?
- What are you trying to achieve?
- How are you trying to achieve it?
- What happened?
- Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
We would like to adjust the content of the Alert that is sent to MS Teams.
Hi @eti,
I suggest that you take a look at this thread post as it is only related to Alert templating and I am sure that you will find your answer there.
In case not then please ask there because there are many active users involved and so far almost all of them have found what they had asked.
Thanks
