Greetings everyone.
I need community help as im far away from deep ES or Grafana knowledge.
I made setup by following manual:
NGINX produces logs in following manere:
log_format json_logs '{"@timestamp":"$time_iso8601","host":"$hostname",'
'"server_ip":"$server_addr","client_ip":"$remote_addr",'
'"xff":"$http_x_forwarded_for","domain":"$host",'
'"url":"$uri","referer":"$http_referer",'
'"args":"$args","upstreamtime":"$upstream_response_time",'
'"responsetime":"$request_time","request_method":"$request_method",'
'"status":"$status","size":"$body_bytes_sent",'
'"request_body":"$request_body","request_length":"$request_length",'
'"protocol":"$server_protocol","upstreamhost":"$upstream_addr",'
'"file_dir":"$request_filename","http_user_agent":"$http_user_agent"'
I was taken this dashboard
Everything looks not bad, data going ok to Grafana and showing on Dashboard.
So here is my problems:
I have few backend API points behind NGINX and i need to make a stats for each backend with response code statistics - like for example:
API endpoint on my service /backend/api
200 - 97%,
404 - 1 %,
502 - 2 %
How can i manage such thing? create a pie graph for each api endpoint?
Or maybe other way: bars with multiple data in each bar.
